Ana içeriğe geç
Nikon COOLPIX S610c LCD Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX S610c LCD Replacement, Battery: adım 1, 1 resimden 1.
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c LCD Replacement: adım 2, 1 resimden 1.
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c LCD Replacement: adım 3, 1 resimden 1.
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c LCD Replacement, Rear Casing: adım 4, 1 resimden 1.
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c LCD Replacement: adım 5, 1 resimden 1.
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c LCD Replacement: adım 6, 1 resimden 1.
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c LCD Replacement: adım 7, 1 resimden 1.
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c LCD Replacement: adım 8, 2 resimden 1. Nikon COOLPIX S610c LCD Replacement: adım 8, 2 resimden 2.
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c LCD Replacement: adım 9, 2 resimden 1. Nikon COOLPIX S610c LCD Replacement: adım 9, 2 resimden 2.
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c LCD Replacement: adım 10, 2 resimden 1. Nikon COOLPIX S610c LCD Replacement: adım 10, 2 resimden 2.
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c LCD Replacement, LCD: adım 11, 2 resimden 1. Nikon COOLPIX S610c LCD Replacement, LCD: adım 11, 2 resimden 2.
    • Pry the display from the rear casing using a spudger.
Sonuç
Kevin Backers
304 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012 üyesi
CPSU-REGAN-W12S9G5
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 718
