Giriş
If your camera isn't taking photos properly, and you need to replace the lens assembly, follow this guide to remove the current assembly.
Neye ihtiyacın var
Remove the three 3x3mm screws that attach the front casing to the bottom.
Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
