Giriş
If camera no longer works at all, then it might be time to replace the motherboard. Follow this guide to remove the motherboard from your camera.
Neye ihtiyacın var
Remove the three 3x3mm screws that attach the front casing to the bottom.
Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
Once the lens assembly has been removed, the mother board cannot be disassembled any further.
Neredeyse bitti!
Sonuç
