Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your rear casing needs to be replaced, if it's been cracked for example, follow this guide to remove the current rear case. In this guide ZxY denotes a screw with Z-length and Y-width.
Parçalar
Hiçbir parça belirtilmedi.
  1. On the bottom right of the camera, locate the battery flap switch.
    • On the bottom right of the camera, locate the battery flap switch.
  2. Move this switch to the right so the battery flap can flip open.
    • Move this switch to the right so the battery flap can flip open.
  3. Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Remove the three 3x3mm screws attached to the rear casing.
    • Remove the three 3x3mm screws attached to the rear casing.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. The panel can be identified by the wifi logo on its upper half on the camera's side.
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  7. Pry the panel off from the bottom using your fingernail.
    • Pry the panel off from the bottom using your fingernail.
  8. Remove the 3x2mm screw underneath the panel near the top of the camera.
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  9. Remove the 4x3mm on the opposite side near the selector wheel. Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  10. Pry the back panel away from the body of the camera, using the space you just opened up. Be careful not to damage the ribbon cable on the opposite end of the camera.
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  11. Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables. The center connector is detached by flipping the black latch up and away from the center of the camera.
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Backers
301 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012 üyesi
CPSU-REGAN-W12S9G5
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 800
