Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
On the bottom right of the camera, locate the battery flap switch.
Move this switch to the right so the battery flap can flip open.
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Remove the three 3x3mm screws attached to the rear casing.
Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Pry the panel off from the bottom using your fingernail.
Remove the 3x2mm screw underneath the panel near the top of the camera.
Remove the 4x3mm on the opposite side near the selector wheel.
Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Pry the back panel away from the body of the camera, using the space you just opened up.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
Bir başkası bu kılavuzu tamamladı.
