Ana içeriğe geç
Nikon CoolPix S5 Buttons Replacement
Neye ihtiyacın var
  1. Nikon CoolPix S5 Buttons Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Buttons Replacement: adım 2, 1 resimden 1.
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Buttons Replacement: adım 3, 2 resimden 1. Nikon CoolPix S5 Buttons Replacement: adım 3, 2 resimden 2.
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Buttons Replacement: adım 4, 2 resimden 1. Nikon CoolPix S5 Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Buttons Replacement: adım 5, 2 resimden 1. Nikon CoolPix S5 Buttons Replacement: adım 5, 2 resimden 2.
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Buttons Replacement: adım 6, 2 resimden 1. Nikon CoolPix S5 Buttons Replacement: adım 6, 2 resimden 2.
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Buttons Replacement, Buttons: adım 7, 1 resimden 1.
    • The plate holding the buttons is on the right side of the camera. Use your fingers to open it to the right, away from the LCD screen. Do not twist or force the panel open. It should lift easily.
  8. Nikon CoolPix S5 Buttons Replacement: adım 8, 1 resimden 1.
    • Pull on ribbon cables to disconnect ribbon cables.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Patty Richeson
99 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G5
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 536
