Ana içeriğe geç
Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
Neye ihtiyacın var
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 2, 1 resimden 1.
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 3, 2 resimden 1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 3, 2 resimden 2.
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 4, 2 resimden 1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 4, 2 resimden 2.
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 5, 2 resimden 1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 5, 2 resimden 2.
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 6, 2 resimden 1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: adım 6, 2 resimden 2.
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: adım 7, 2 resimden 1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: adım 7, 2 resimden 2.
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Josh Miller
87 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G5
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 465
