Ana içeriğe geç
Nikon CoolPix S600 Motherboard Assembly Replacement
Neye ihtiyacın var
  1. Nikon CoolPix S600 Motherboard Assembly Replacement, Front and Rear Casing: adım 1, 1 resimden 1.
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 4, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 5, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 5, 2 resimden 2.
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 8, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 8, 2 resimden 2.
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 10, 3 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 10, 3 resimden 2. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 10, 3 resimden 3.
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Motherboard Assembly Replacement, Lens Assembly: adım 11, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement, Lens Assembly: adım 11, 2 resimden 2.
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 13, 1 resimden 1.
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 14, 1 resimden 1.
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 15, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 15, 2 resimden 2.
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 16, 2 resimden 1. Nikon CoolPix S600 Motherboard Assembly Replacement: adım 16, 2 resimden 2.
    • Gently separate the camera lens from the mother board.
  17. Nikon CoolPix S600 Motherboard Assembly Replacement, Motherboard Assembly: adım 17, 1 resimden 1.
    • The mother board is permanently fixed to the battery housing.
    • Mother board cannot be taken a part any further.
Sonuç
Bir başkası bu kılavuzu tamamladı.
andreas anggasastra
116 İtibar
5 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G6
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 1,301
