Giriş
Replacing the logic board of a Nikon Coolpix 3500
Parçalar
Hiçbir parçaya gerek yok.
  1. Unlatch the battery cover. Slide the cover out and flip it open.
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
    • Remove the two 4.5 mm screws that sit inside the battery slot.
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the logic board.
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
    • Detach the grey-capped wire.
    • Detach the green chip that sits next to the blue wires.
    • Remove the 3.5 mm screw that sits next to the rotating lens.
    • Invert the logic board and lens to uncover the orange and blue ribbon cables. These cables still connect the logic board to the LCD screen.
    • Detach the blue ribbon cable.
    • Detach the orange ribbon cable by using a spudger, and while pushing it out horizontally.
    • Detach the red-capped wire.
    • Lift the logic board and lens, which are still connected, out of the back cover.
    • Lift the black covering and remove the orange ribbon cable, which connects the lens to the logic board.
Sonuç
richard guenther
183 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G38
5 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,877
