Ana içeriğe geç
Nikon Coolpix 5400 Battery Door Replacement
Neye ihtiyacın var
  1. Nikon Coolpix 5400 Battery Door Replacement, Battery Door: adım 1, 1 resimden 1.
    • Remove one 3mm Phillips #0 screw from the top of the camera back cover.
  2. Nikon Coolpix 5400 Battery Door Replacement: adım 2, 1 resimden 1.
    • Remove three 3mm Phillips #0 screws from the side of the back cover.
  3. Nikon Coolpix 5400 Battery Door Replacement: adım 3, 1 resimden 1.
    • Lift memory card flap.
    • Remove one 3mm Phillips #0 screw from the side of the back case.
  4. Nikon Coolpix 5400 Battery Door Replacement: adım 4, 1 resimden 1.
    • Remove four 3mm Phillips #0 screws from the bottom of the back case.
  5. Nikon Coolpix 5400 Battery Door Replacement: adım 5, 2 resimden 1. Nikon Coolpix 5400 Battery Door Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to gently pop the back case away from the body of the camera.
    • Pull the back case away from the camera very gently.
    • The connecting cables are very fragile and easily broken.
  6. Nikon Coolpix 5400 Battery Door Replacement: adım 6, 1 resimden 1.
    • Flip camera over so the bottom is facing up.
    • Push the sliding latch to open the battery door.
    • Push the press fit pin firmly with a flat-head screwdriver to release it from the hinge housing.
    • Push to the left, half the length of the pin.
  7. Nikon Coolpix 5400 Battery Door Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Grasp the press fit pin firmly with precision tweezers to pull it from the housing.
    • Do not to drop the pin into the camera body.
  8. Nikon Coolpix 5400 Battery Door Replacement: adım 8, 1 resimden 1.
    • Remove the battery door by lifting it out of the camera body.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 244
