Giriş
This guide will allow a user to replace the battery door on the Nikon Coolpix 5400.
The back housing must be removed to access the press fit pin holding the battery door.
Be careful not to drop the press fit pin into the body of the camera when removing with the tweezers.
A flat head screwdriver, a Phillips #0 screwdrivers, tweezers, and a plastic opening tool are required for this replacement.
Remove the battery before beginning any work to prevent electrical shock.
Neye ihtiyacın var
