Ana içeriğe geç
Nikon Coolpix 775 Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix 775 Screen Replacement, Battery: adım 1, 3 resimden 1. Nikon Coolpix 775 Screen Replacement, Battery: adım 1, 3 resimden 2. Nikon Coolpix 775 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 2, 2 resimden 2.
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Screen Replacement: adım 3, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 3, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 3, 3 resimden 3.
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Screen Replacement, Motherboard: adım 4, 3 resimden 1. Nikon Coolpix 775 Screen Replacement, Motherboard: adım 4, 3 resimden 2. Nikon Coolpix 775 Screen Replacement, Motherboard: adım 4, 3 resimden 3.
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Screen Replacement: adım 5, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 5, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 5, 3 resimden 3.
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Screen Replacement: adım 6, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 6, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Screen Replacement: adım 7, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 7, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 7, 3 resimden 3.
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Screen Replacement: adım 8, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 8, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 8, 3 resimden 3.
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Screen Replacement: adım 9, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 9, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 9, 3 resimden 3.
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Screen Replacement: adım 10, 2 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 10, 2 resimden 2.
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Screen Replacement: adım 11, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 11, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 11, 3 resimden 3.
    • Pull the ribbon connected to the dial off the motherboard.
  12. Nikon Coolpix 775 Screen Replacement, Screen: adım 12, 2 resimden 1. Nikon Coolpix 775 Screen Replacement, Screen: adım 12, 2 resimden 2.
    • Remove the orange ribbon cable from its connector by firmly but gently pulling it.
  13. Nikon Coolpix 775 Screen Replacement: adım 13, 2 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 13, 2 resimden 2.
    • Pull out the pink cable connector.
    • If it's not coming loose, use a pair of needle nose pliers to get a good grip on the connector.
  14. Nikon Coolpix 775 Screen Replacement: adım 14, 3 resimden 1. Nikon Coolpix 775 Screen Replacement: adım 14, 3 resimden 2. Nikon Coolpix 775 Screen Replacement: adım 14, 3 resimden 3.
    • Grab the back of the screen and gently lift up.
    • It is only held on by adhesive so it should come out relatively easy.
Sonuç
Nick Meador
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Baechle Fall 2018 IUPUI, Team S2-G3, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G3
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 381
