Ana içeriğe geç
Nikon Coolpix 7900 Front Cover Replacement
Neye ihtiyacın var
    1. Nikon Coolpix 7900 Front Cover Replacement, Back Cover: adım 1, 1 resimden 1.
      • Remove the four 3.0mm screws on the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix 7900 Front Cover Replacement: adım 2, 1 resimden 1.
      • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix 7900 Front Cover Replacement: adım 3, 1 resimden 1.
      • Remove the two 3.0mm screws on the right side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix 7900 Front Cover Replacement: adım 4, 1 resimden 1.
      • Carefully open the back cover. Take care as there are connectors still attached.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix 7900 Front Cover Replacement: adım 5, 1 resimden 1.
      • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix 7900 Front Cover Replacement: adım 6, 1 resimden 1.
      • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
      • The back cover will be disconnected from the camera
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix 7900 Front Cover Replacement, Front Cover: adım 7, 1 resimden 1.
      • Be careful of metallic parts which are loose and will fall out.
      • Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix 7900 Front Cover Replacement: adım 8, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix 7900 Front Cover Replacement: adım 9, 1 resimden 1.
      • Remove front cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kaky Payne
121 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G38
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,887
