Ana içeriğe geç
Nikon Coolpix 7900 LCD Screen Replacement
Neye ihtiyacın var
    1. Nikon Coolpix 7900 LCD Screen Replacement, Back Cover: adım 1, 1 resimden 1.
      • Remove the four 3.0mm screws on the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix 7900 LCD Screen Replacement: adım 2, 1 resimden 1.
      • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix 7900 LCD Screen Replacement: adım 3, 1 resimden 1.
      • Remove the two 3.0mm screws on the right side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix 7900 LCD Screen Replacement: adım 4, 1 resimden 1.
      • Carefully open the back cover. Take care as there are connectors still attached.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix 7900 LCD Screen Replacement: adım 5, 1 resimden 1.
      • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix 7900 LCD Screen Replacement: adım 6, 1 resimden 1.
      • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
      • The back cover will be disconnected from the camera
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix 7900 LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
      • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
      • Carefully flip the screen down to reveal the back of the screen
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix 7900 LCD Screen Replacement: adım 8, 1 resimden 1.
      • Disconnect the ribbon cable and gray connector with red and black wires.
      • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kaky Payne
121 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G38
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 2,098
