Giriş
If you're having problems with your memory card, this guide will show you how to remove and replace your memory card in the Nikon Coolpix 995.
  1. Set camera so the memory card compartment is facing you.
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Now that the Memory card compartment is open, carefully remove the memory card.
    • Now that the Memory card compartment is open, carefully remove the memory card.
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Layman
89 İtibar
3 adet Kılavuz yazıldı
Takım
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G5
5 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 4
Her zaman: 1,693
