Ana içeriğe geç
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: adım 1, 2 resimden 1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: adım 1, 2 resimden 2.
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: adım 2, 1 resimden 1.
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: adım 3, 2 resimden 1. Nikon Coolpix 995 Memory Card Replacement: adım 3, 2 resimden 2.
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Layman
89 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G5
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 2,400
