Ana içeriğe geç
Nikon Coolpix A900 Monitor Replacement
Neye ihtiyacın var
    1. Nikon Coolpix A900 Monitor Replacement, Battery: adım 1, 1 resimden 1.
      • Orient the camera so that it is upside down, with the lens facing towards you.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix A900 Monitor Replacement: adım 2, 2 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 2, 2 resimden 2.
      • Slide the battery door lock left to unlock it.
      • The battery door will automatically open.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix A900 Monitor Replacement: adım 3, 2 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 3, 2 resimden 2.
      • Slide the yellow tab up to release the battery.
      • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
      • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix A900 Monitor Replacement, Rear Case: adım 4, 3 resimden 1. Nikon Coolpix A900 Monitor Replacement, Rear Case: adım 4, 3 resimden 2. Nikon Coolpix A900 Monitor Replacement, Rear Case: adım 4, 3 resimden 3.
      • Orient the camera upside down, with the lens facing away from you.
      • Remove the two 3mm Phillips #00 screws from the right.
      • Remove the two 3.4mm Phillips #00 screws from the left.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix A900 Monitor Replacement: adım 5, 3 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 5, 3 resimden 2. Nikon Coolpix A900 Monitor Replacement: adım 5, 3 resimden 3.
      • Turn the camera on its side, with the lens facing away from you.
      • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix A900 Monitor Replacement: adım 6, 3 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 6, 3 resimden 2. Nikon Coolpix A900 Monitor Replacement: adım 6, 3 resimden 3.
      • Place the camera upright with the lens facing away from you.
      • Move the monitor down, and remove two 4.4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix A900 Monitor Replacement: adım 7, 2 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 7, 2 resimden 2.
      • Remove the two black 2.5 mm screws from the monitor bracket.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix A900 Monitor Replacement: adım 8, 2 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 8, 2 resimden 2.
      • Return the monitor to the closed position.
      • Gently open the rear case.
      • You may need opening tools to help separate the rear case.
      • Be careful when opening the rear case to not damage the ribbon connectors.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix A900 Monitor Replacement: adım 9, 3 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 9, 3 resimden 2. Nikon Coolpix A900 Monitor Replacement: adım 9, 3 resimden 3.
      • Place the camera lens down, while supporting the rear case.
      • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
      • With the ribbons disconnected, you can now remove the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix A900 Monitor Replacement, Monitor: adım 10, 3 resimden 1. Nikon Coolpix A900 Monitor Replacement, Monitor: adım 10, 3 resimden 2. Nikon Coolpix A900 Monitor Replacement, Monitor: adım 10, 3 resimden 3.
      • Set the rear case screen down.
      • Remove the two 2.5 mm black Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix A900 Monitor Replacement: adım 11, 2 resimden 1. Nikon Coolpix A900 Monitor Replacement: adım 11, 2 resimden 2.
      • Separate the rear case from the monitor assembly.
      • Make sure that the ribbon cable does not snag on the rear case when removing it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
4Kılavuz Yorumları
Where did you get a new monitor for your camera?
photower - Yanıt Paylaş
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
Laurent Farrugia - Yanıt Paylaş
This is excellent but where would you get a new 3” monitor?
Panders McMulluon - Yanıt Paylaş
Have you tried AliExpress or Ebay?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 68
Her zaman: 2,114
