Ana içeriğe geç
Nikon Coolpix AW130 Battery Door Replacement
Neye ihtiyacın var
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Battery Door Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Battery Door Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Battery Door Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: adım 5, 2 resimden 1. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: adım 6, 1 resimden 1.
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: adım 7, 2 resimden 1. Nikon Coolpix AW130 Battery Door Replacement: adım 7, 2 resimden 2.
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: adım 8, 1 resimden 1.
    • Pull the battery door away from the camera body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
6 Yorum
Where can I purchase the battery cover?
Thanh Tran - Yanıt
Where can I buy the AW130 battery door?
Jose - Yanıt
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - Yanıt
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - Yanıt
Need web site to order battery door?
Connie Mossor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 4,132
