Ana içeriğe geç
Nikon Coolpix AW130 Battery Replacement
  1. Nikon Coolpix AW130 Battery Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Battery Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - Yanıt
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 Battery Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Battery Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
Sonuç
1Rehber Yorum
Try the following before ordering your battery :
The problem with my cool pix aw130 was the little yellow plastic tab ( seen in one of the above photos ; step 3 ) that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
Franklin Noel Stein - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 2,634
