Ana içeriğe geç
Nikon Coolpix AW130 LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: adım 5, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: adım 5, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: adım 8, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: adım 10, 3 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: adım 10, 3 resimden 2. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: adım 10, 3 resimden 3.
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: adım 11, 2 resimden 1. Nikon Coolpix AW130 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Sonuç
8Kılavuz Yorumları
Hi.
Where can you buy a replacement screen?
Ben - Yanıt
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Yanıt
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Yanıt
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Yanıt
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 3,149
