Ana içeriğe geç
Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement
Neye ihtiyacın var
  1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: adım 5, 3 resimden 1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: adım 5, 3 resimden 2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: adım 5, 3 resimden 3.
    • Using the spudger, pry the plastic button face from the camera body.
    • The sharp edges of the spudger could cut you or pierce an exposed battery.
  6. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
  7. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: adım 7, 1 resimden 1.
    • Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
    • From there, the buttons should dislodge from their plastic casing.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 737
