Ana içeriğe geç
Nikon Coolpix AW130 Shutter Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: adım 5, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: adım 5, 2 resimden 2.
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: adım 6, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 6, 2 resimden 2.
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 2.
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 2. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,182
