Giriş
This guide shows how to replace the assembly of the shutter button/mode selector dial/buttons. This assembly can be replaced if any of the buttons malfunction or are faulty. The back cove and bracket need to be removed before removing the button assembly.
Neye ihtiyacın var
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Lift the corner under the power button up.
While at the same time pushing the selector knob back.
3 farklı kişi bu kılavuzu tamamladı.
