Giriş
This guide shows how to replace the flash assembly on a Nikon Coolpix B700 when the bulb stops working.
We have to separate the Nikon Coolpix B700 camera starting with the back frame, then we can open the camera and take internal parts out. After that, you can see the flash unit from inside and replace it easily. Make sure to remove the battery before beginning the work on the flash unit.
For the old flash unit, you can see https://www.epa.gov/recycle/electronics-... so you could recycle
Neye ihtiyacın var
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
Remove the single 6mm screw.
Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
Using a Phillips screwdriver, remove the two 6 mm screws that hold the flash assembly.
Bir başkası bu kılavuzu tamamladı.
