Ana içeriğe geç
Nikon Coolpix B700 Lens Assembly Replacement
Neye ihtiyacın var
    1. Nikon Coolpix B700 Lens Assembly Replacement, Back Frame Assembly: adım 1, 1 resimden 1.
      • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix B700 Lens Assembly Replacement: adım 2, 1 resimden 1.
      • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix B700 Lens Assembly Replacement: adım 3, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 3, 2 resimden 2.
      • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
      • Open the HDMI flap to remove a 5.5mm screw.
      • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix B700 Lens Assembly Replacement: adım 4, 1 resimden 1.
      • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix B700 Lens Assembly Replacement: adım 5, 3 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 5, 3 resimden 2. Nikon Coolpix B700 Lens Assembly Replacement: adım 5, 3 resimden 3.
      • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
      • While twisting, pry apart the shell to split the camera in half.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix B700 Lens Assembly Replacement: adım 6, 1 resimden 1.
      • Be careful not to damage the ribbons that connect the halves together.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon Coolpix B700 Lens Assembly Replacement: adım 7, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 7, 2 resimden 2.
      • Place the pry tool under the black latch. Lift gently until the latch flips up.
      • Gently pull the ribbon away from the latch.
      • Be gentle when taking ribbons out and apart because they are fragile.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix B700 Lens Assembly Replacement, Internal Bracket: adım 8, 1 resimden 1.
      • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
      • Remove the single 6mm screw.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix B700 Lens Assembly Replacement: adım 9, 1 resimden 1.
      • Insert the pry tool under the latch and gently lift up to remove the ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix B700 Lens Assembly Replacement: adım 10, 1 resimden 1.
      • Move the ribbon out of the way to reveal the hidden screw.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix B700 Lens Assembly Replacement: adım 11, 1 resimden 1.
      • Lift the button assembly gently to give access to remove the 4mm screw.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix B700 Lens Assembly Replacement: adım 12, 1 resimden 1.
      • On the top of the camera, remove the 6mm screw.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix B700 Lens Assembly Replacement: adım 13, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 13, 2 resimden 2.
      • With the spudger tool gently pry off the white tap holding in the bracket.
      • Use the same tool to remove the glued-on ribbon.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon Coolpix B700 Lens Assembly Replacement: adım 14, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 14, 2 resimden 2.
      • Gently lift up the button assembly to slide the bracket out.
      FixBot'a Sor
      Yorum Ekle
    8. Nikon Coolpix B700 Lens Assembly Replacement: adım 15, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 15, 2 resimden 2.
      • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
      • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: adım 16, 2 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: adım 16, 2 resimden 2.
      • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix B700 Lens Assembly Replacement: adım 17, 1 resimden 1.
      • Remove the tripod mount from it's slot.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix B700 Lens Assembly Replacement: adım 18, 3 resimden 1. Nikon Coolpix B700 Lens Assembly Replacement: adım 18, 3 resimden 2. Nikon Coolpix B700 Lens Assembly Replacement: adım 18, 3 resimden 3.
      • Now you just have to slide the lens assembly out of the housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
Per Benny Paulsen - Yanıt Paylaş
how to reset an objective error? the lens is stopped in the middle of a hike
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 79
Her zaman: 4,004
