Ana içeriğe geç
Nikon Coolpix B700 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon Coolpix B700 Motherboard Replacement, Back Frame Assembly: adım 1, 1 resimden 1.
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Motherboard Replacement: adım 3, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Motherboard Replacement: adım 5, 3 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 5, 3 resimden 2. Nikon Coolpix B700 Motherboard Replacement: adım 5, 3 resimden 3.
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Motherboard Replacement: adım 6, 1 resimden 1.
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Motherboard Replacement: adım 7, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 7, 2 resimden 2.
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Motherboard Replacement, Internal Bracket: adım 8, 1 resimden 1.
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Motherboard Replacement: adım 9, 1 resimden 1.
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Motherboard Replacement: adım 10, 1 resimden 1.
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Motherboard Replacement: adım 12, 1 resimden 1.
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Motherboard Replacement: adım 13, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 13, 2 resimden 2.
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Motherboard Replacement: adım 14, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 14, 2 resimden 2.
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Motherboard Replacement: adım 15, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 15, 2 resimden 2.
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Motherboard Replacement, Motherboard: adım 16, 1 resimden 1.
    • Use the metal spudger to open the latch to remove the ribbon.
  17. Nikon Coolpix B700 Motherboard Replacement: adım 17, 1 resimden 1.
    • Use the Phillips screwdriver to remove the single 6 mm screw.
  18. Nikon Coolpix B700 Motherboard Replacement: adım 18, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 18, 2 resimden 2.
    • Gently lift the button assembly. Slide the motherboard out from the shell.
  19. Nikon Coolpix B700 Motherboard Replacement: adım 19, 2 resimden 1. Nikon Coolpix B700 Motherboard Replacement: adım 19, 2 resimden 2.
    • Desolder the black, gray, and white wires from the motherboard.
    • The motherboard is labeled with the wire colors.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Nikon b700 all sorts part demegs
Rathod Umesh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 644
