Giriş
This guide shows how to replace the motherboard and battery housing. This can be replaced if there are any issues with the battery connectivity or the board blows out.
Neye ihtiyacın var
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Place the pry tool under the black latch. Lift gently until the latch flips up.
Gently pull the ribbon away from the latch.
How to check the rear part my b700 will turn ON when i disconected the 2 ribbons
Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
Remove the single 6mm screw.
2 farklı kişi bu kılavuzu tamamladı.
