Ana içeriğe geç
Nikon Coolpix E5700 Rear LCD Replacement
Neye ihtiyacın var
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: adım 1, 2 resimden 2.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: adım 3, 1 resimden 1.
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: adım 4, 2 resimden 1. Nikon Coolpix E5700 Rear LCD Replacement: adım 4, 2 resimden 2.
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: adım 5, 2 resimden 1. Nikon Coolpix E5700 Rear LCD Replacement: adım 5, 2 resimden 2.
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: adım 6, 1 resimden 1.
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: adım 7, 1 resimden 1.
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: adım 8, 1 resimden 1.
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: adım 9, 1 resimden 1.
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: adım 10, 1 resimden 1.
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Sitton
351 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G58
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 2,434
