Ana içeriğe geç
Nikon Coolpix L18 Front Cover Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L18 Front Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Front Cover Replacement: adım 2, 2 resimden 1. Nikon Coolpix L18 Front Cover Replacement: adım 2, 2 resimden 2.
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Front Cover Replacement: adım 3, 1 resimden 1.
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Front Cover Replacement, LCD Screen: adım 4, 1 resimden 1.
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Front Cover Replacement: adım 5, 1 resimden 1.
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Front Cover Replacement: adım 6, 1 resimden 1.
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Front Cover Replacement, Front Cover: adım 7, 1 resimden 1.
    • Pry back the front cover of the camera starting from the right side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea Govea
360 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G23
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 14
Her zaman: 3,255
