Ana içeriğe geç
Nikon Coolpix L18 LCD Screen Replacement
Neye ihtiyacın var
    1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: adım 1, 1 resimden 1.
      • Remove the memory stick from the camera.
      • Remove the batteries from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix L18 LCD Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix L18 LCD Screen Replacement: adım 2, 2 resimden 2.
      • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
      • There is one screw hidden under the AV cover that also needs to be removed.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix L18 LCD Screen Replacement: adım 3, 1 resimden 1.
      • Pry the back cover from the left side of the camera. Remove the cover gently.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
      • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
      • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix L18 LCD Screen Replacement: adım 5, 1 resimden 1.
      • Remove the tape on the right side of the LCD screen.
      • Gently lift the LCD screen from its base.
      • Don't tug on the screen because it is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix L18 LCD Screen Replacement: adım 6, 1 resimden 1.
      • Lift the black latch connecting the LCD ribbon to the motherboard.
      • Gently pull the LCD ribbon out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Nonny
234 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G23
4 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
Good work! Appreciate it.
Oasis World - Yanıt Paylaş
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - Yanıt Paylaş
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 7,766
