Giriş
In this guide, we will give you step-by-step instructions on how to detach the lens from the logic board so that it can be replaced or repaired.
Neye ihtiyacın var
Remove the memory stick from the camera.
Remove the batteries from the camera.
Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
Remove the LCD base plate.
6 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
