Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
In this guide, we will give you step-by-step instructions on how to detach the lens from the logic board so that it can be replaced or repaired.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the memory stick from the camera.
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver. There is one screw hidden under the AV cover that also needs to be removed.
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Pry the back cover from the left side of the camera. Remove the cover gently.
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. This is where energy for the flash is stored.  Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Remove the tape on the right side of the LCD screen.
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  7. Lift the black latch connecting the LCD ribbon to the motherboard.
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  8. Pry back the front cover of the camera starting from the right side.
    • Pry back the front cover of the camera starting from the right side.
  9. Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard. Remove the LCD base plate.
    • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
    • Remove the LCD base plate.
  10. Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the lens ribbon out.
  11. Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
    • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
  12. Lift up the black and copper covering on the left side of the camera.
    • Lift up the black and copper covering on the left side of the camera.
  13. Pull the wiring at the top right of the camera away from the lens with tweezers.
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  14. Remove the cross-hair shaped wire cap to the left of the lens.
    • Remove the cross-hair shaped wire cap to the left of the lens.
  15. Remove the 3 screws holding the lens to the camera frame. Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  16. There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andrea Govea
357 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G23
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - Yanıt
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 15,982
