Giriş
To repair these parts of the camera, you will need to use a screwdriver and a spudger tool. This guide is necessary if you want to repair other parts of the camera such as the LCD screen. There are many screws in this camera, so always check to make sure you found all of them as you work on it.
Neye ihtiyacın var
Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
my battery compartment will not close. can I buy a new one
This worked for the pin. I’m guessing it pushes through the front of the body behind the screen. I didn’t get that far. It for sure will not pull out of the back. I cut the pin and pulled it out (yes it did damage the plastic). I cut a small nail (brad) the put it through the cover and placed the brad in where the old pin was and placed a bit of super glue on it to hold it in place (don’t get any on the new cover). In a while I will assemble the camera and add more super glue. Yes, the super glue will be visible, but it will take some searching to find it and will look much better that a tie-wrap or tape. I hope that helps.
