Ana içeriğe geç
Nikon Coolpix L26 Camera Front Cover Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: adım 1, 3 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: adım 1, 3 resimden 2. Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera Front Cover Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera Front Cover Replacement: adım 3, 1 resimden 1.
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera Front Cover Replacement: adım 4, 1 resimden 1.
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera Front Cover Replacement: adım 5, 3 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement: adım 5, 3 resimden 2. Nikon Coolpix L26 Camera Front Cover Replacement: adım 5, 3 resimden 3.
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera Front Cover Replacement: adım 6, 2 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement: adım 6, 2 resimden 2.
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera Front Cover Replacement: adım 7, 1 resimden 1.
    • Gently pull the cover off the camera.
  8. Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: adım 8, 3 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: adım 8, 3 resimden 2. Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: adım 8, 3 resimden 3.
    • Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
    • Do not pull on the LCD screen; there is a ribbon of circuitry that is connected to the motherboard.
  9. Nikon Coolpix L26 Camera Front Cover Replacement: adım 9, 1 resimden 1.
    • Gently hold the LCD screen down, so the ribbon lays flat against the back of the camera.
  10. Nikon Coolpix L26 Camera Front Cover Replacement: adım 10, 1 resimden 1.
    • Gently wedge the spudger underneath the white latch and lift the latch open.
  11. Nikon Coolpix L26 Camera Front Cover Replacement: adım 11, 2 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement: adım 11, 2 resimden 2.
    • Use the flat side of the spudger to flip the white switch on the motherboard. You should hear a light click.
  12. Nikon Coolpix L26 Camera Front Cover Replacement: adım 12, 1 resimden 1.
    • Gently pull the ribbon out of the switch.
  13. Nikon Coolpix L26 Camera Front Cover Replacement, Front Cover: adım 13, 2 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement, Front Cover: adım 13, 2 resimden 2.
    • Open the battery compartment door by sliding the white switch upwards. Push the door towards the right of the camera.
  14. Nikon Coolpix L26 Camera Front Cover Replacement: adım 14, 3 resimden 1. Nikon Coolpix L26 Camera Front Cover Replacement: adım 14, 3 resimden 2. Nikon Coolpix L26 Camera Front Cover Replacement: adım 14, 3 resimden 3.
    • Hold the camera with the lens face down to prevent the plastic covers of the warning light and the flash bulb from falling out.
    • Take a firm hold of the black inner casing of the top and bottom of internal camera. With your other hand, take a hold of the red front case.
    • With slight force, pull the internal camera upwards and out of the front case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sadie
427 İtibar
3 adet Kılavuz yazıldı
Ekip
San Diego State, Team 1-3, Sheppard Winter 2015 San Diego State, Team 1-3, Sheppard Winter 2015 üyesi
SDSU-SHEPPARD-W15S1G3
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 2,655
