Ana içeriğe geç
Nikon Coolpix L27 Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L27 Screen Replacement, Screen: adım 1, 3 resimden 1. Nikon Coolpix L27 Screen Replacement, Screen: adım 1, 3 resimden 2. Nikon Coolpix L27 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix L27 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: adım 3, 3 resimden 1. Nikon Coolpix L27 Screen Replacement: adım 3, 3 resimden 2. Nikon Coolpix L27 Screen Replacement: adım 3, 3 resimden 3.
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: adım 4, 2 resimden 1. Nikon Coolpix L27 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: adım 5, 3 resimden 1. Nikon Coolpix L27 Screen Replacement: adım 5, 3 resimden 2. Nikon Coolpix L27 Screen Replacement: adım 5, 3 resimden 3.
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: adım 6, 1 resimden 1.
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: adım 7, 1 resimden 1.
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: adım 8, 2 resimden 1. Nikon Coolpix L27 Screen Replacement: adım 8, 2 resimden 2.
    • Remove the cable from the camera.
    • Lift the screen out.
Sonuç
Vishalpreet Sandhu
157 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Yanıt
where can i buy a screen replacement please
mo0nflwr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 960
