Giriş
If you notice that your Nikon Coolpix L320 camera is failing to power on, it may be due to the camera’s batteries being dead. Batteries provide the electrical power necessary for the camera to turn on and operate. However, dead batteries will not give the power necessary to perform this function. Replacing the batteries will help your camera to function once again.
This quick guide will walk you through the process of replacing your camera’s old batteries with a new set. Before you begin, make sure your camera is completely turned off. The batteries may be hot immediately after using the camera so practice caution when removing them. Also, make sure to only use one type of battery for all four slots as mixing and matching may cause the camera to not turn on. Let's get started!
Neye ihtiyacın var
Flip the camera over to reveal the card/battery door.
Slide the button to the unlocked position and the door should pop open.
