Ana içeriğe geç
Nikon Coolpix L320 LCD Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L320 LCD Replacement, Batteries: adım 1, 2 resimden 1. Nikon Coolpix L320 LCD Replacement, Batteries: adım 1, 2 resimden 2.
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 LCD Replacement: adım 2, 2 resimden 1. Nikon Coolpix L320 LCD Replacement: adım 2, 2 resimden 2.
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
  3. Nikon Coolpix L320 LCD Replacement, LCD: adım 3, 3 resimden 1. Nikon Coolpix L320 LCD Replacement, LCD: adım 3, 3 resimden 2. Nikon Coolpix L320 LCD Replacement, LCD: adım 3, 3 resimden 3.
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
  4. Nikon Coolpix L320 LCD Replacement: adım 4, 1 resimden 1.
    • Use an opening tool or spudger to separate the front and back of the camera.
  5. Nikon Coolpix L320 LCD Replacement: adım 5, 1 resimden 1.
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
  6. Nikon Coolpix L320 LCD Replacement: adım 6, 1 resimden 1.
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
Sonuç
MollyHenderson
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Ramos Spring 2023 UMass Dartmouth, Team 5-6, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 272
