Giriş
This guide will show you how to access the LCD screen to replace it, or simply clean dust from under the clear plastic cover.
Neye ihtiyacın var
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
Insert the tips of your fingers into the space between the screen and back-plate.
Gently lift the screen up and out of the frame.
5 farklı kişi bu kılavuzu tamamladı.
