Ana içeriğe geç
Nikon Coolpix L340 Buttons Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: adım 1, 1 resimden 1.
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: adım 4, 1 resimden 1.
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: adım 5, 1 resimden 1.
    • Push buttons out of the back of the cover.
Sonuç
Robert Estrella
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 1,211
