Ana içeriğe geç
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: adım 1, 2 resimden 1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: adım 1, 2 resimden 2.
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: adım 2, 1 resimden 1.
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelly Kryzak
140 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,433
