Ana içeriğe geç
Nikon Coolpix L610 Control Panel Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: adım 1, 2 resimden 1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: adım 1, 2 resimden 2.
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Control Panel Replacement: adım 2, 1 resimden 1.
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Control Panel Replacement: adım 3, 1 resimden 1.
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Control Panel Replacement: adım 4, 3 resimden 1. Nikon Coolpix L610 Control Panel Replacement: adım 4, 3 resimden 2. Nikon Coolpix L610 Control Panel Replacement: adım 4, 3 resimden 3.
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Control Panel Replacement, Control Panel: adım 5, 3 resimden 1. Nikon Coolpix L610 Control Panel Replacement, Control Panel: adım 5, 3 resimden 2. Nikon Coolpix L610 Control Panel Replacement, Control Panel: adım 5, 3 resimden 3.
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Control Panel Replacement: adım 6, 1 resimden 1.
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
Sonuç
Jeremy
1.072 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 15
Her zaman: 599
