Giriş
We will show the you as the reader how to disassemble the Nikon L610 LCD screen and replace it with a new one. We do this carefully removing the screws, keeping careful track of all the pieces removed and attaching a new screen to the motherboard of the camera.
Neye ihtiyacın var
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
