Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Is your flash not lighting up? This guide will show you how to replace the flash from your camera.
  1. Remove two 5 mm Phillips #000 screws below the flash component.
    • Remove two 5 mm Phillips #000 screws below the flash component.
    • In order to complete this step the flash must be open. To open the flash press the button located above the lens on the leftward side of the camera.
  2. Use blue plastic opening tool to pry open the casing for the flash.
    • Use blue plastic opening tool to pry open the casing for the flash.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the plastic casing surrounding the flash.
    • Remove the plastic casing surrounding the flash.
  5. Pull the wires connecting the flash out of the camera. Pull the wires connecting the flash out of the camera.
    • Pull the wires connecting the flash out of the camera.
  6. Unsolder the wires that connect the flash component. Unsolder the wires that connect the flash component. Unsolder the wires that connect the flash component.
    • Unsolder the wires that connect the flash component.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emilio Mena
725 İtibar
4 adet Kılavuz yazıldı
Takım
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G1
4 Üyeler
3 Yorum
It's not a comment, but where did you obtain the replacement flashbulb?
hgdddee - Yanıt
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
wildstreaksavannahs - Yanıt
I can't get into bulb
Szabolcs Demeter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,538
