Ana içeriğe geç
Nikon Coolpix L810 LCD Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L810 LCD Replacement, LCD: adım 1, 2 resimden 1. Nikon Coolpix L810 LCD Replacement, LCD: adım 1, 2 resimden 2.
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 LCD Replacement: adım 2, 2 resimden 1. Nikon Coolpix L810 LCD Replacement: adım 2, 2 resimden 2.
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 LCD Replacement: adım 3, 2 resimden 1. Nikon Coolpix L810 LCD Replacement: adım 3, 2 resimden 2.
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 LCD Replacement: adım 4, 1 resimden 1.
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 LCD Replacement: adım 5, 2 resimden 1. Nikon Coolpix L810 LCD Replacement: adım 5, 2 resimden 2.
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 LCD Replacement: adım 6, 3 resimden 1. Nikon Coolpix L810 LCD Replacement: adım 6, 3 resimden 2. Nikon Coolpix L810 LCD Replacement: adım 6, 3 resimden 3.
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 LCD Replacement: adım 7, 2 resimden 1. Nikon Coolpix L810 LCD Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emilio Mena
752 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G1
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - Yanıt
Congratulations! Perfect lesson !
I need HELP presentation abowt desassembler / remove motherboard and other parts to repair the lenz move mechanism. Unfortunately NIKON left Brazil and the resident Suport tecnician besides not being good, stay in quarentine (corona virus)! Special Thanks for you help! Best regards
ramos.eng - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 2,592
