Ana içeriğe geç
Nikon Coolpix L810 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L810 Motherboard Replacement, LCD: adım 1, 2 resimden 1. Nikon Coolpix L810 Motherboard Replacement, LCD: adım 1, 2 resimden 2.
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 Motherboard Replacement: adım 2, 2 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 Motherboard Replacement: adım 3, 2 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 Motherboard Replacement: adım 4, 1 resimden 1.
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 Motherboard Replacement: adım 5, 2 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 5, 2 resimden 2.
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 Motherboard Replacement: adım 6, 3 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 6, 3 resimden 2. Nikon Coolpix L810 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 Motherboard Replacement: adım 7, 2 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
  8. Nikon Coolpix L810 Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. Nikon Coolpix L810 Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. Nikon Coolpix L810 Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
    • Remove three 5 mm Phillips #000 screws bordering the motherboard.
  9. Nikon Coolpix L810 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the plastic component located directly behind the flash from its rubberized holder.
  10. Nikon Coolpix L810 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the electric tape covering the wires.
  11. Nikon Coolpix L810 Motherboard Replacement: adım 11, 3 resimden 1. Nikon Coolpix L810 Motherboard Replacement: adım 11, 3 resimden 2. Nikon Coolpix L810 Motherboard Replacement: adım 11, 3 resimden 3.
    • Unsolder all the wires that are on the top of the motherboard near the flash component.
  12. Nikon Coolpix L810 Motherboard Replacement: adım 12, 1 resimden 1.
    • Unsolder the wires on the bottom end of the motherboard.
    left out how to get screw out by power button so can pull board off. not seeing a way to ?
    jon baker - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emilio Mena
752 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G1
4 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
The guide is incomplete! Do not try to remove the mobo for it is soldered to some other tiny board under the on/off switch. Trying to remove the mobo after just unscrewing it, may guide to certain and permanent destruction of both PCBs!!!
symeonleriou - Yanıt
any clue how to get tiny mobo out with mobo after taking screw out of tiny one at on/off switch?
jon baker - Yanıt
This guide should be for beginners, Mr. Symeon Leriou, and you will not only write "Mobo", but also motherboard or Mainboard or Hauptplatine (deutsch)
But I agree with you that it is not complete.
The motherboard is soldered to the on / off board (power supply for the batteries).
Soldering again is almost impossible ...
lothar4460 - Yanıt
Exactly! The guide is GOOD but it is incomplete!
The solder removal is insufficient to release de motherboard.
How to do it?
ramos.eng - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 3,090
