Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The LCD screen is an essential component of a camera. If the LCD screen stops working, the camera can no longer be used. In this repair guide, you will learn how to replace the LCD screen on the Nikon Coolpix L820 camera.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the battery before beginning. Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera. Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Remove the front top Phillips screw with the screwdriver. Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly. Be sure to only apply pressure to the casing panels and not the sensitive internal electronics. Once the rear housing is separated, the settings buttons will be accessible for replacement.
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Remove the front casing to expose the LCD screen and wires. Do not damage the exposed wires. Do not damage the exposed wires.
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Using the tweezers, lift the hinges connecting the two ribbon wires to the camera. Using the tweezers, lift the hinges connecting the two ribbon wires to the camera. Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Once the flexible ribbon wires are disconnected, remove the LCD screen. Once the flexible ribbon wires are disconnected, remove the LCD screen.
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucas Otto
107 İtibar
1 Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 13
Son 30 gün: 36
Her zaman: 1,812
