Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
Remove the front top Phillips screw with the screwdriver.
Open the empty battery slot on the bottom of the camera, revealing four additional screws.
Unscrew the four Phillips screws with the screwdriver.
Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
Once the rear housing is separated, the settings buttons will be accessible for replacement.
Remove the front casing to expose the LCD screen and wires.
Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
Once the flexible ribbon wires are disconnected, remove the LCD screen.
2 farklı kişi bu kılavuzu tamamladı.
