Ana içeriğe geç
Nikon Coolpix L820 Shutter Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: adım 1, 3 resimden 1. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: adım 1, 3 resimden 2. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: adım 1, 3 resimden 3.
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Shutter Button Replacement: adım 2, 2 resimden 1. Nikon Coolpix L820 Shutter Button Replacement: adım 2, 2 resimden 2.
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Shutter Button Replacement: adım 3, 3 resimden 1. Nikon Coolpix L820 Shutter Button Replacement: adım 3, 3 resimden 2. Nikon Coolpix L820 Shutter Button Replacement: adım 3, 3 resimden 3.
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: adım 4, 3 resimden 1. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: adım 4, 3 resimden 2. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: adım 4, 3 resimden 3.
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 Shutter Button Replacement: adım 5, 3 resimden 1. Nikon Coolpix L820 Shutter Button Replacement: adım 5, 3 resimden 2. Nikon Coolpix L820 Shutter Button Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 Shutter Button Replacement: adım 6, 2 resimden 1. Nikon Coolpix L820 Shutter Button Replacement: adım 6, 2 resimden 2.
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
  7. Nikon Coolpix L820 Shutter Button Replacement, Shutter Button: adım 7, 1 resimden 1.
    • Remove these five Phillips screws, from the back of the camera, with the Phillips screwdriver.
  8. Nikon Coolpix L820 Shutter Button Replacement: adım 8, 1 resimden 1.
    • Using the pointed edge of the spudger, lift the hinge that secures this flex circuit. This will unfasten the flexible ribbon wire.
  9. Nikon Coolpix L820 Shutter Button Replacement: adım 9, 1 resimden 1.
    • Remove the panel containing the shutter and zoom slider, by lifting it up.
  10. Nikon Coolpix L820 Shutter Button Replacement: adım 10, 1 resimden 1.
    Satın Al
    • Remove the metal cover using tweezers to allow access to the shutter button.
    • Replace shutter button.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jimmy Kendall
137 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G4
3 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
cyrez_1509 - Yanıt
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
JM Palacios - Yanıt
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
Massimino Diquarto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 3,244
