Ana içeriğe geç
Nikon Coolpix L840 Lanyard Ring Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: adım 1, 3 resimden 1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: adım 1, 3 resimden 2. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: adım 1, 3 resimden 3.
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Lanyard Ring Replacement: adım 2, 1 resimden 1.
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Lanyard Ring Replacement: adım 3, 2 resimden 1. Nikon Coolpix L840 Lanyard Ring Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: adım 4, 2 resimden 1. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: adım 4, 2 resimden 2.
    • Identify lanyard ring.
    • Unscrew the 4 mm black screw with a Philips 000.
  5. Nikon Coolpix L840 Lanyard Ring Replacement: adım 5, 2 resimden 1. Nikon Coolpix L840 Lanyard Ring Replacement: adım 5, 2 resimden 2.
    • Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abraham Lozano
595 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G11
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 652
