Ana içeriğe geç
Nikon Coolpix L840 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Nikon Coolpix L840 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: adım 3, 2 resimden 1. Nikon Coolpix L840 Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Abraham Lozano
595 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G11
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - Yanıt
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 2,031
